[PIC] decimal to bcd converting
rasool4
Newbie level 1
Newbie level 1
hi
i use 16f877a programmer for programming and for showing 3digit number in 7segment i use decimal to bcd code my code it work well when i use goto for calling decimal to bcd code but when i use call instruction for calling this code itis not work well . this is my program
         PAGESEL     DECIMAL
         CALL       DECIMAL                 ;CONVERT IDECIMAL TO BCD
        PAGESEL     $
DECIMAL
        SWAPF       MATH_HIGH,W
        ANDLW       0FH
        ADDLW       0F0H
        MOVWF       THOUSANDS
        ADDWF       THOUSANDS,F
        ADDLW       0E2H
        MOVWF       HUNDREDS
        ADDLW       32H
        MOVWF       ONES
        MOVF        MATH_HIGH,0
        ANDLW       0FH
        ADDWF       HUNDREDS,F
        ADDWF       HUNDREDS,F
        ADDWF       ONES,F
        ADDLW       0E9H
        MOVWF       TENS
        ADDWF       TENS,F
        ADDWF       TENS,F
        SWAPF       MATH_LOW,W
        ANDLW       0FH
        ADDWF       TENS,F
        ADDWF       ONES,F
        RLF         TENS,F
        RLF         ONES,F
        COMF        ONES,F
        RLF         ONES,F
        MOVF        MATH_LOW,W
        ANDLW       0FH
        ADDWF       ONES,F
        RLF         THOUSANDS,F
        MOVLW       07H
        MOVWF       TENK
        MOVLW       0AH
LB1
        ADDWF       ONES,F
        DECF        TENS,F
        BTFSS       3,0
        GOTO        LB1
LB2
        ADDWF       TENS,F
        DECF        HUNDREDS,F
        BTFSS       3,0
        GOTO        LB2
LB3
        ADDWF       HUNDREDS,F
        DECF        THOUSANDS,F
        BTFSS       3,0
        GOTO        LB3
LB4
        ADDWF       THOUSANDS,F
        DECF        TENK,F
        BTFSS       3,0
        GOTO        LB4
   RETURN
i dont now why when i use below code for callind decimal part it works well
         PAGESEL     DECIMAL
        goto      DECIMAL
        PAGESEL     $
comebakdecimal
but when i use call instruction for calling this part it is not work
There is nothing in your code that will stop it from being called correctly. The PIC has only 8 levels of stack, perhaps you have exceed this.
If you must run "CALL DECIMAL" as the first instruction, then do it like this:
   call decimal
   goto end
decimal
...... your program here.....
   return
end   end
Then it should work. Without "goto end" the program will come back after hitting "RETURN", it will execute DECIMAL again and after hitting RETURN for the second time, the stack pointer would be screwed and wonders into no_where_land.
Allen
