whoami1
Newbie level 2
- Joined
- Dec 4, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 15
Hello,
my miner do not start because i try to update the firmware and the power was gone..
so now the miner start but only the red flash is flashing and i can not connect via LAN.
i try the debug ( thants for the pic, you are the only man in the internet that show this.. )
but i have problems whit my debug Sad
My Miner: Antminer S3
Some tuturial for Help me..
https://bitcointalk.org/index.php?topic=330665.msg9640895#msg9640895
but my result:
Start only Miner:
thats all
and when i press the Reset button and start then i get:
can someone help me?
sorry for my bad englisch, is the most people here do not unterstand me, then i ask a frend to translate
but my result:
Start only Miner:
¦¦UI¦¦?1.1.4 (Apr 11 2013 - 01:45:00)
U-boot for ELink, build by huangfc(QQ:343669866)
Taobao:http://huangfc.taobao.com
model:ELink M150
DRAM: 64 MB
lE¦¦?¦¦¦¦on for 1s...
id read 0x100000ff
flash size 8388608, sector count = 128
Flash: 8 MB
U¦¦default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize...
: cfg1 0x5 cfg2 0x7114
eth0: 00:03:7f:ff:ff:ff
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:ff:ff:fe
athrs26_reg_init_lan
ATHRS26: resetting s26
ATHRS26: s26 reset done
eth1 up
eth0, eth1
Autobooting in 1 seconds,Press p to stop autoboot!!
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.10.12 (xxl@ubuntu) (gcc version 4.6.4 (OpenWrt/Linaro GCC 4.6-2013.05 r38031) ) #140 Mon Jul 21 17:27:04 CST 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=TL-WR741ND-v4 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61336k/65536k available (2187k kernel code, 4200k reserved, 588k data, 232k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.100000] MIPS: machine is TP-LINK TL-WR741ND v4
[ 0.100000] MAC FF:FF:FF:FF:FF:FF
[ 0.100000] MAC 20:59:a0:c9:47:0e
[ 0.560000] bio: create slab <bio-0> at 0
[ 0.560000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.580000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.580000] TCP: Hash tables configured (established 512 bind 512)
[ 0.590000] TCP: reno registered
[ 0.590000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.600000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.610000] NET: Registered protocol family 1
[ 0.630000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.630000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.640000] msgmni has been set to 119
[ 0.650000] io scheduler noop registered
[ 0.650000] io scheduler deadline registered (default)
[ 0.650000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.670000] console [ttyATH0] enabled, bootconsole disabled
[ 0.680000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.690000] m25p80 spi0.0: unrecognized JEDEC id 014017
[ 0.710000] libphy: ag71xx_mdio: probed
[ 0.710000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 1.260000] eth0: Found an AR7240/AR9330 built-in switch
[ 2.300000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 2.850000] ag71xx ag71xx.0 eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.860000] TCP: cubic registered
[ 2.860000] NET: Registered protocol family 17
[ 2.870000] 8021q: 802.1Q VLAN Support v1.8
[ 2.870000] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 2.880000] Please append a correct "root=" boot option; here are the available partitions:
[ 2.890000] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
thats all
U-Boot 1.1.4 (Apr 11 2013 - 01:45:00)
model:ELink M150
DRAM: 64 MB
led turning on for 1s...
id read 0x100000ff
Flash: 8 MB
Using default environment
In: serial
Out: serial
Err: serial
eth0 up
eth1 up
eth0, eth1
Enter Backup Mode...
eth1 link down
eth0 link down
eth1 link down
uip init...
http init...
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
eth1 link down
