ABADY1000
Newbie
I have a project on ZYNQ7000 chip, I read data from image sensor, apply some processing on the received images, and show it on a display using BT656 protocol.
The problem is that there are many timing issues, and every time I make even a slight modification and regenerate the bit-stream there is a risk new generated bit-stream won't work properly.
I contacted someone to help me fixing timing issues, and he solved it (Vivado shows no timing errors), but after I run the project I found the function of the system is not working properly!
So, what I am asking about is where to go next? What is the method I should follow to fix my problem?
Someone suggested I make post-implementation simulation, the problem here is I am using zynq7000, how would I simulate CPU and RAM(memory)? would using QEMU help me applying post-implementation simulation? or do I need to?
