dead time interval in modified sine wave inverter
--BawA--
Advanced Member level 1
Noida, INDIA
Hello everyone
I just wanted to know the time duration of the dead time in modified sine wave of 50Hz ?
The dead-band depends on rise-time and fall-time of your switch.
Modified sinewave refers to a particular waveform. Sort of a b-ish sinewave. I had an inverter that produced this shape.
Two cycles take 40 msec. Output goes to 0V for 5 mSec at a time.
ok. in this way the interval when the output is zero depends on your reference voltage and amplitude of your DC link.
thanks everyone for your replies ,
one more thing to ask , is sg3525 ic capable of generating this waveform posted by bradtherad?
The waveforms can be generated by a pulse generator, flip-flop, and logic gates.
The final outputs 1 & 2 are alternating 25% duty cycle. They are suitable to control an H-bridge.
Bradtherad , u didn't answer my question in post #5
Sorry, I have no direct experience with control IC's such as the sg3525.
Here is a webpage which speaks of it having a built-in oscillator, range 100 Hz to 550 kHz.
I believe you can take alternating states from two output pins.
FvM said:
If you manage to setup the error amplifier for a fixed duty cycle...
but the dutycycle will vary as a function of output voltage.
Why? The PWM controller can be either used with feedback to regulate a voltage or with fixed duty cycle but not both at the same time.
Thanks FvM , i got it ...
I'll try to implement it on hardware within a couple of days..
