SergeyBondarev
Junior Member level 1
Hello guys,
I want to launch TV demonstration example for Altera DE2 board using PAL input signal. The example is built for NTSC input signal, and works fine. I looked into the datasheet of the TV decoder and corrected register initialization data in the verilog file "I2C_AV_Config.v" to autodetect input signal. But this step didn't help. What do you think could be another problem?
Thanks
Thanks
