De0 flash memory vhdl code
sss-90
Newbie level 3
Newbie level 3
DE0 flash memory vhdl code
Hello,
I'm going to design project by using this device DE0 ( cyclone III EP3C16F484 )
Really, I'm new in using the FPGA Device.
In the project , I should use flash memory to write/read input data .
I have researched for getting the source code for flash memory but unfortunately No results for this.
Is there Any one can help me if u have the vhdl source code of flash memory?
If no , Any suggestions for this or method to write the code?
regards
I suggest getting started with the basics. Start working through a VHDL tutorial.
thank you for ur reply
I have learned enough in writing VHDL code
I wrote my main program code ,only I need flash memory source code.
