Nov 6, 2008 #1 C cafukarfoo Full Member level 3 Joined Jul 25, 2007 Messages 170 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 2,510 sdram operation Hi Sir/Madam, Does anyone have a good documentation on the DDR SDRAM operation? Thanks.
Nov 6, 2008 #2 V vlsi_whiz Full Member level 4 Joined Nov 12, 2005 Messages 216 Helped 49 Reputation 98 Reaction score 24 Trophy points 1,298 Location Penang Activity points 3,139 ddr sdram operation Check out the following PDF: https://download.micron.com/pdf/datasheets/dram/ddr/128MBDDRx4x8x16D.pdf Its a 128Mb DDR SDRAM 333MHz from Micron. The data sheet will give you details as to structure, working and timing of DDR memory. You can also check out the Micron site for other memory types (SDRAM, DDR, DDR2, DDR3,etc).
