dc_compiler: create_generated_clock from a generated clock?
TonyLS
Member level 3
Member level 3
Boston, MA
What are the negative effects if any of generating a clock from a previously generated clock? Both of which will use the create_generated_clock command.
The following is mentioned in the documentation, does any one know what is meant by "overwrites the attributes on the generated_clock object"? Are they referring to the original generated clock or the new one? I don't see how it can effect the original gen_clock. Any input will be appreciated.
From documentation:
Using create_generated_clock on an existing generated_clock object overwrites the attributes of the generated_clock object.
