DC solid state relay , how to make cheaply
Electro nS
Full Member level 6
Full Member level 6
i have tried to use a AC solid state relay to connect / disconnect a DC load. with failure due to zero crossing ....etc..
i have searched the internet and the prices of DC relays (mosfets instead of traics..or thyristors) are quite expensive !
So why not build my own !?? after all it is just a mosfet , driver and some logic , right ?
any ideas ?
note : The load is DC 12-48 , current around 50A continous . this relay is used as the power supply switch (ON/OFF), instead of using HUGE electromechnical relay or switches .
my basic idea is to use N MOS with half bridge driver , or a P-MOS (although it is quite hard to find good ones with low RDSon) on the HIGH side
or use N MOS without driver on the lower side ( to disconnect GND instead of VCC to the load ) , but i donot know if keep the load floating is that OK ??
please share any experience or ideas , i would appreaciate
thanks :-o
