WhyWhy
Member level 4
- Joined
- Mar 18, 2013
- Messages
- 68
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,779
You probably can, depending on the control voltage source.It cannot direct supply to the PMOS gate without any resistor?
Two points should be considred however
- you don't want to leave the gate terminal floating
- if you supply a higher voltage than +/- 20V between gate and source of the MOSFET, the transistor will immediately destroyed. It looks like this might happen in your circuit.
