Jun 9, 2005 #1 D dearjohn Newbie level 5 Joined Jun 8, 2005 Messages 9 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,357 generate sdf for pt Q1 How to use DC to generate .sdf from .db(come from Foundry) if use "write_sdb -output top.sdf" ==> DC show error message ( -outpur only support by PT) Q2 Need and constrain when generate SDF?????
Jun 9, 2005 #2 N nand_gates Advanced Member level 3 Joined Jul 19, 2004 Messages 899 Helped 175 Reputation 350 Reaction score 53 Trophy points 1,308 Activity points 7,037 how to generate sdf from dc Try using PT to do this!
Jun 9, 2005 #3 J JesseKing Advanced Member level 4 Joined Nov 12, 2004 Messages 100 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 838 dc sdf in dc, use write_sdf -version 2.1 top.sdf. btw, you can consult sold for more infomation. Best regards.
Jun 10, 2005 #4 C claint Member level 5 Joined May 21, 2004 Messages 94 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Activity points 762 JesseKing is right . use write_sdf -version to write out sdf file.
Jun 10, 2005 #5 S sheayone Newbie level 1 Joined Mar 10, 2005 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,288 The syntax is >write_sdf [-version sdf_version] [-significant_digits digits] [-instance inst_name]file_name from sold
Jun 10, 2005 #6 D dearjohn Newbie level 5 Joined Jun 8, 2005 Messages 9 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,357 what different between write_sdf and write_timing??
Jun 10, 2005 #7 S spauls Advanced Member level 2 Joined Dec 17, 2002 Messages 524 Helped 26 Reputation 52 Reaction score 9 Trophy points 1,298 Activity points 3,355 USE PT , AS DC will not consider wire load model into effect , This may cause problem in POST LAYOUT simulation.
