peyro
cheap dc to dc isolation converter
Hello,
I need to add (2) 4/20mA ports into a MCU based controller for industrial process control. I am isolating the digital MCU circuit from the 4/20mA ports with a linear optoisolator and opamp but I need to also isolate the power supplies of both circuits. My question is if somebody can suggest a good isolation DC/DC converter (input can be in the range of 12 to 36Volts and output should be 12Volts and current is around 80mA).
The second question is if I feed the two 4/20mA ports with the same Dc/Dc converter, will it cause ground loop problems on the sensors (it is a level sensor and a temperature probe)??? if so how it can be avoided without add another Dc/Dc converter???
Excuse me with these questions, I am new with 4/20mA ports...
Thanks in advance for any help and regards,
peyro
Hello,
peyro
