DC-DC Converter Reverse Polarity?
digi001
Full Member level 5
Full Member level 5
Hi I am making a PCB that has power coming into the board as 12V and 5V.
However I also need a on-board -12V power rail for some OpAmps. If I use a 12Vto12V isolated DC-DC Brick, then connect it up backwards so that output 12V is ground and output GND is 12V, would this give me the -12V that I need?
What is a better way to do this?
See the isolated converter output side as a 12V-battery, does it work?
A better way (cheaper, higher efficieny) is an inverting buck-boost converter.
Reactions: digi001
    digi001
I see your point as a Battery. Its just a floating voltage, so Yes. Thanks.
Thanks for this suggestion. So I would need to pick out an IC Controller and build a inverting buck-boost? This would be non-isolated, but inverting? Wouldn't this take up more real-estate than a DC-DC brick? Isn't a DC-DC brick just a compact completed solution of a buck-boost or maybe flyback if isolated?
How much current do you need?
If it is only a few mA, you could do it with a charge pump IC like the ICL7660
Reactions: digi001
    digi001
Depending on how good it has to be, you might be able to
take a capacitor coupled feed off the switching node, and
two more diodes plus another cap gives you a charge pump.
You'll have those diodes' offset of course, but most op amps
don't care a whole lot about common mode offset (the effect
of asymmetric power supplies) or you might even be improving
the common mode position if your input common mode is
above ground.
Reactions: digi001
    digi001
