DC-DC boost converter for low voltage application
hridz
Junior Member level 3
Tezpur, India
hi,
I need a low voltage dc-dc boost converter circuit for solar panel application.
maximum voltage= 2V
maximum current= 380mA
doraemon
Super Moderator
Staff member
Japan
Hello!
I would like to reply, but there is no question.
And there is no indication whether 2V is the input or the output.
And in either case, the other voltage is missing.
Dora.
hridz
Tezpur, India
Thanks for the reply..
2V is the maximum output voltage of the panel and input voltage will start from 0V.
I need the circuit design of the converter..
thanks
with regards
hridz
doraemon
Super Moderator
Staff member
Japan
Hello!
There is still no question in your post. Could you please formulate a clear question?
How do you want us to know if you are looking for a place to buy one, for the type
of a converter corresponding to various specs (that by the way are missing), etc...
You want a converter, and I am talking about the converter, so let's say clearly:
In = input of the CONVERTER
Out = output of the CONVERTER
What I was asking is:
In this case, In = 0 ~ 2V
Out = ???
Current = ???
When you know that, you can go to https://digikey.com and choose your converter.
Beside this, you will not find any converter that converts from 0 V. It will start at, say,
0.8 ~ 0.9 V (maybe less, that's just an order of magnitude).
Dora.
Reactions: hridz
    hridz
