Datasheet of Toshiba T7889 LCD controller
radioman
Junior Member level 3
Netherlands
Hello,
Has anyone the datasheet of the Toshiba T7889 LCD controller. I've got a few of them in a 2*20 character LCD display. I need to programm it with a microcontroller.
Please help. :?
Thanks !
Radioman
2x20 lcd controller
I don't have datasheet but I have similar lcd too, it has 2 chips named T7889 and T 6961A. LCD is 2x20 characters. On PCD is printed RCM 2027.
This controller (lcd )is not 100% compatible with HD44780. Communication with lcd is same as with HD44780, but must use different instructions.
rcm2027
Hello Priewan,
Do you have the instruction set for this type of LCD-controller ?
Regards, Radioman
6961a lcd
No I haven't, I try combination of bits based on normal instruction set and see what it doing.
My display with this controller have 14 pins, but pins 10 (D3), 9(D2), 8(D1) are directly on display PCB connected to ground! So only 4-bit communication is possible. Initialization is like with normal HD44780, but next instruction (1st in 4bit mode) must be something like this 00110111.
HD44780: 001 DL N F * *, DL=DataLength,N=Numlines,Font,*=don't care
T7889 : 001 DL N F A B, DL=blink cursor,N=don't care,F=show cursor,A=show text(if 0 only moving cursor, but no text),B=MUST BE 1(if 0, display don't work!!!)
So, try...
Trap sa trap, nie je to az take tazke...
2x20 lcd display datasheet
Priewan,
Thanks for the info. I will give it a try. As soon as I have more results I will post it.
I have asked Toshiba for the docs, but they don't reply at all.
Radioman
