data transmission based on ModBus Protocol
AliBahar
Member level 2
Member level 2
Hi friends
I want to create function which performs data communication based on Modbus Protocol using C programming (ANSI C).
I ll appreciate for any useful proposals and guidances.
hello,
RTU or ASCII ?
Master or Slave (or both!) ?
RS232 or TCP/IP ?
some example on MikroE site..
i tested a Pic as master for an modbus 8 I/O +4EA slave interface.
Modicon PLC was (is ?) a reference for modbus application.
RTU or ASCII ?
RS232 or TCP/IP ?
you are right. I had to determine more specifications.
RTU, Master and Slave and rs232.
I want to create function which can be supportable with all micro-controllers and all C compilers.
If "supportable" is aware of the need to write a platform specific wrapper for UART and particularly timer functions, this can work.
Did you already review the code links at modbus.org site? https://www.modbus.org/tech.php
