tojeena
Member level 3
For the given Block diagram I am having following doubts for the digitizer(data compression part).
1.The input signal will be a sine signal rt? will sample it and make it digital.After that will apply fft and for then will apply data compression algorithm arithmetic coding and then for error correction will apply turbo codes.Is this procedure ok?
2.Is this an innovative approach or any new approaches can be made to this.
Expectiong your kind reply.
