While working with the 10-bit DAC MCP4911, the control word being sent via SPI is 0x7000.
As per the attached snapshots, the 10-bit data transmitted is 0, while the voltage reference should be unbuffered, internal gain should be 1x and Vout should be activated.
0 as the data translated to 0V at the output of the DAC. However, there is an offset voltage of 0.5V despite of applying the specified control word. I have observed this problem even in MCP4822, which is a 12-bit DAC. The output fails to go below this value.
The DAC operates for any other values specified. But the output is scaled between VREF(+) to 0.5V instead of VREF(+) to 0V (VSS).
Could someone please suggest a remedy to go around this?
ADC_VREF is the reference voltage generated by REF02D. It is given to the MCU for as the ADC reference and it is also the reference for the DAC. VDD is 5V.
