Phataas
I am trying to excite with a 2V voltage over a 1k resistor and then feed this current into a current-to-voltage converter with a 1k resistor in the feedback loop. This seems to not work as I expect. I am powering the op. amps. with single supply voltage. Maybe the current flowing from the output of the CTV converter to the inverting input can't be "generated" and I need to use dual supply voltage (±Vcc instead of 0 <-> Vcc)?
I do measure 2mA as expected over R2, but the voltage on the U2 output is about 1V (half).
I expect to get about 2V on the output when exciting with 2V.
I have drawn the circuit I have built, maybe someone can point out errors.
Dual supply fixed the problem. Is there a way to solve this with single supply?
