Shady Ahmed
Member level 5
- Joined
- Jan 26, 2013
- Messages
- 86
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 2,042
Based on what i understand from the following architecture , i started the Current steering DAC design
I calculated the current as ((1.2-0.6)/R) / 2 ) ... (the 2 multiplied is for the compensation (because it is RZ).
As u can see, i designed the Cascode mirrors with 1.1 Mohm & 800 KOhm for the NMOS & PMOS respectively.
The 2 branches to the right are to dissipate the current and don't push it to the summing node in the 2 cases ( D0 is high and Clock is High )
Here is the DAC DC analysis (image 1 )
And here is the DAC inserted to the system ( image 2)
where V+ & V- are the summing nodes
However , when i used it in the system , the SQNR is decreased by 17 db or so ...
Here are FFT for the O/P using the IDEAL DAC (the first figure , SNR = 78.6 dB ) & CURRENT STEERING DAC (the second figure , SNR = 60.7 dB) - with the same differential input (0.45)
If it helps.
I used this architecture
If it helps.
