biolycans
Member level 2
- Joined
- Aug 24, 2013
- Messages
- 50
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 478
Hi all,
I have a question related to the current source load. For example if I have a common source amplifier with a Resistor Rd as a load, if My transistor NMOS is in the saturation mode then the differences between the Rd and resistance of the NMOS is huge because the transistor is acting like a current source so its impedance is huge and the voltage drop on it will be bigger than the voltage drop in Rd,
But in many books, I found that the common source has a current source as a load (this a PMOS), why ?
And in the differential amplifier, in many books I read that the load of this circuit is current. Why ?
If I see this like a voltage divider, I will have a resistor of the PMOS and the resistor of the NMOS and those resistances will be of the same order of value, so my voltage drop on boths transistor will be similar , so I don ´t know the reason I use this configuration.
regards
joaquin
regards
joaquin
