Dear All
I'm going to build a step up from 12 Vdc to 300 Vdc/ 300 watt using push pull topology in current mode configuration, as i have to sens current wich is about 37A with duty cycle 45% for each transistor
the peak sens voltage <= 1 volt
so i nees 25 mOHM/30watt resistor which is expensive and loosy solution
i wounder if i can sens secondary current(1 A) dose this affect the Current mode topology?????????
also i'm thinking about buildig a PCB transformer to sens the current
my Idea is to pass the 37A trace as close as possible to a spile constructed by PCB traces dose this idea work??????
also i'll use Ti uc3825B wich is 4.8$/1K pcS dose anyone know a less costly push pull driver????????????
thanks
