I'm designing a CP slot antenna, so it's important to get know the excitation current phase on the slot. I'm simulating it using IE3D, so can I get information about it (in graph) for example the phase different between the two slot.
I hope someone could give me full explanation on it.
There are a few things you can do to check for the phase of current or the effect of the phase differences:
1. Find the current data:
(1). You can display the current distribution on IE3D/MGRID.
(2). Select File->Save Current Density Data. MGRID will save the current data into an ASCII file and you can read it.
2. You can display the vector current animation. You will see the current vectors are rotating circularly if your antenna is a good CP.
3. You can check the axial ratio to see the phase of the effect of current phase.
