Current mirror and mismatch
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi guys,
I would like to make a small experiment regarding current mismatch in a current mirror for different transistors area (or sizes).
I know that we have to do that using monte carlo (or maybe the dcmatch can work, I don't know). But the thing is how should I do the calculation to get the mismatch? And should I use any kind of special circuit alongside with the current mirror?
Regards.
I would use the Monte-Carlo simulation.
The result should be like the bigger transistors have lowest mismatch (standard deviation Std.Dev).
So, use the Std Dev parameter as a mismatch factor.
