ant17
Member level 2
hi i am currently building transmitter for a experimental project which has main driving Transistor which i want to be able to limit the current through the transistor to 12v at 6 amps which normal resistors are out as they would burn up i have thought of inductive current limiting but by frequency through inductor you would need something in the nano Henry range if it was run in megahertz range can anyone tell me what the normal way to limit the current is
