current limiting circuits ...?
bulerias
Junior Member level 1
hi,
where can i find current limit circuits (for 50ma current)example to build from scratch,
and is there any ICs that do that as a singke solution?
thanks for any help...
bull
year
Member level 3
Member level 3
Please check Classic Current Limit Circuit TR based.
Transistor is very cost effective and robust.
M!k
Advanced Member level 2
You can also use a programmable voltage regulator (e.g. LM117/317) + additional resistor.
Take a look at LM117/317's datasheet.
Mik
sc/mp
Full Member level 2
Full Member level 2
Try : JFET + resistor
sc/mp
Full Member level 2
Full Member level 2
This link shows you the current limiting with a N chanel JFET.
---> h**p://www.huebsch.at/train/Elektronik/Beleuchtung.htm
You must use a JFET with IDSS > 50mA
Check also power dissipation in the JFET
Here is my curves from Proteus (not the same JFET !) :
The resistor biases negativly the Gate.
You must adjust resistor to catch your current limiting value.
jzaghal
Full Member level 2
Full Member level 2
50ma Current Limit !!!
A very nice current limit would be to use the TL431A chip
whis is widely available.
Look for it's datasheet on the www.
Bye.
sc/mp
Full Member level 2
Full Member level 2
Yes, TL431 is a good idea :
Bye
penrico
Full Member level 5
Full Member level 5
Argentina
I think, using a transistor is a good sollution
In the image, the current is fixed by the formula: (Vdiode-0,7)/R
