Your calculation for idealized devices is correct, but if you want a more realistic result you should consider that LTspice models take into account parasitic elements which are present in actual devices, as for example, the highest inductor, the highest series resistance, which means that for an inductor of about 1H, its series resistance would lie in the same range of the above active load (R1), that is, close to a hundred ohms. In short, for "real-world" devices, the current would be likely much smaller than what was calculated.
