Harryz
Newbie level 3
- Joined
- Nov 19, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 52
Good day. I have only 0.75A but I need 2A. How can I boost my 0.75 to become 2A? Need urgently. Thanks
Ignore post #2 which is complete nonsense!
Correct citation would be much appreciated!
I appreciate your attempt to get a clearer statement from the original poster. I think we should await his clarification.Do you need the 2A current has a burst current which lasts for some 2 or 3 seconds or it has to be continuous current..
Sorry to confuse you guys.
My source is a battery, of course DC, that has an output of 19V 3.5A. I have to supply 4 circuits that need 12V 2A, 5V 2A, 12V 1A and 12V 0.9A. I divided 3A into 4 and I got 0.75A. I want that 0.75A boosted to become 2A for those loads.
Thanks for helping.
I'm not sure what you mean by dividing the current will make it not work. The problem with a linear regulator will be the lousy efficiency with 19V-12V and 19V-5V (or even 12V-5V). With the large amount of wasted power you would need much more than the 3.5A from the battery when the loads are at maximum current draw.kripacharya said:A 'normal' linear supply/ converter will not work, since the current WILL have to be divided.
If this is something from a no-name factory in China, you may have something that doesn't even come close to the quoted performance. Most of the power banks (external battery charger) I've seen on the internet especially those from well know manufacturers are in the 20000mAH range, I'm sure there might be some with more, but they all seem to come in packages that are about the same size, a 30000mAH would require a 50% bigger package. If it's not larger than the average external battery charger it's probably not going to give you 30000mAH and their quoted 2 hours of run time.The battery I am saying is a high power bank 30000mAH I found on the internet.
Yes the load will demand a continuous supply for at least 2 hours.
