carbon9
Member level 3
- Joined
- Dec 31, 2006
- Messages
- 60
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,746
I just designed a simple microstrip transmission line and modelled it in CST. I attached the CST project. According to the microstrip design, epsilon of the substrate is 4.6, substrate thickness is 1.6mm, and line width is 3mm. I verified these calculations in 2 different plugins.
The problem is, S11 is always around 0dB and S21 is below -25dB. And this doesn't change when I change the width to a value than 3mm. I think the problem is with the ports I used. Could you please help me to modify the project so that it would work as expected?
Thanks in advance...
