CST port problem, please help me
Leprof
cst-port
Hi all,
I use CST for antenna simulation. I use waveguide port.
For Microstrip antenna, I check and view E and H at the port, it is ok.
But for CPW antenna, I see that the E at the port is along the substrate (see the attatched file for CPW antenna and Microstrip antenna).
Please tell me if we set the same port for CPW antenna and Microstrip antenna ?
Please help me.
Thanks and have fun
cst port
Hi Leprof
Read the manuals (Getting Started for instance) of CST MWS (it could be in pdf format at your documentation sub folder of CST).
You'll have there some examples.
Good luck!
unbalanced cst
Hi tzikhaim,
I read the document but it is not clear.
In fact, I find that in my simulation, there is only ground mode, not even and odd mode.
Please tell me for CPW antenna, which mode shoud I choose ? I how to choose in CST.
Thanksss
itzikhaim said:
Hi Leprof
Good luck!
balanced excitation cst
Hi!
If you want to feed balanced element/antenna you need odd mode excitation.
But if the element is unbalanced you sohuld excite an even mode.
Choose multiport feature when defining your waveguide port.
multiport excite cst
Hi!
cst excitation
Hi Itzikhaim,
Thanks for your help.
But in fact, I could do as you said.
In Waveguide port: I choose Multipin port in Mode Setting, and then in Define Pins, how to define Potential Set Definitions in order to get the port mode as in your picture ?
please tell me how to get 1(1,-)(2,-)... in your picture ?
Thanks very much in advance
Best regards
Added after 4 minutes:
itzikhaim said:
Hi!
Sorry,
I could NOT do as you said.
Please see my picture and tell me pls how to do.
(In fact, I need to excite an CPW antenna).
Thanks so much
Have fun
Added after 3 minutes:
itzikhaim said:
Hi!
Here is the file
Hi Leprof!
Its been a while since I replied your msg.
In your CPW line attached, you excited different modes.
In waveguide multipin port the symbol 1(1,-) means; port 1, mode 1 , negetive pole (direction)
and the symbol 1(1,+) means; port 1, mode 1, positive pole (direction).
This is what you'll need to setup in order to correctly feed your CPW balanced antenna!
Good luck !!!
