Leegit
Newbie level 6
Hello all,
I have been working with CST MWS for about a week now and I am simulating PCB structures, specifically microstrips, both single-ended and differential. I have a lot of experience with 3D modeling and EM solvers. Basically, I was hoping we could share our experiences on what are the ideal settings for the transient solver for ONLY these cases... here is what I have uncovered...
I start by loading up the EDA template so that my units are in [mm/GHz/ns] and my boundary conditions are set to normal with magnetic = 0 for xyz directions...
Transient Solver Parameters
Accuracy = -30 dB or -40 dB [not entirely sure on how this plays a role in the simulation?]
Normalized to fixed impedance -> ON with 50 ohms [electrical world is always compared to ideal 50 ohm ports]
Under Specials -> Line Impedance Adaptation -> ON with 0.1% accuracy and maximum passes = 8. [For my work, I need very high accuracy on Line Impedance, could be higher]
Under Specials -> Electric Shielding -> OFF
Under Specials -> Inhomogenous Port Accuracy Enhancement -> ON
Port Dimensions
Also, a very important part of the simulation is the port setup. I have my port dimensions set to the following:
Port Height = 5*trace_width & Port Width = 10*trace_width [These are the suggested values for port dimensions in IEEE Microwave Magazine Dec. 2008]
Question?
Has anyone come across alternative settings or setups which produce high accuracy while keeping the simulation time under a few minutes?
Port Dimensions
Question?
