Because I wanna create a discrete port at the start and the end point of the helical coil. I therefore created a cyclinder at each point and insert it to the coil (Boolean/Add). My question is: How to make a "beautiful" bending between the cyclinder and the coil like in the first picture in my previous post?
now i get you clearly. it is impossible to make beautiful and uniform like the coil you created from macros. the best way is edit the parameter in macros to make the coil uniform before you creating the coil.
