Vsl
Newbie level 3
Dear all,
I'm trying to do some measurement of coaxial cable on CST.
I found out that if i change the backgrounds conditions or simply the background material, results will be completely different.
I want to simulate a coaxial cable with these dimensions :
-inner conductor outer diameter : 1.52 mm
-outer conductor inner diameter : 3.5 mm
The inner conductor is PEC , the outer conductor is PEC , the dielectric is AIR.
The frequency range is 1 - 32 GHZ.
I'm using these settings:
- waveguide ports on the faces of the dielectric
- Time domain solver ( using the default settings )
- Background material : Normal ( without changing any properties )
- Boundary conditions : Open add space on every plane.
The problem is that if i change one of the setting above, i'll achieve different resaults.
So, could you explain me how to simulate this coaxial in the right way?
Thank you in advice :shock::shock::shock:
Using the time domain solver I also see differences if i simulate in the frequency range 0 - 32 GHz or 1 - 32 GHz, (so, including or not the 0 ) and it was totally unexpected from me.
I really need your help.
