dominik.patscheider@estud
Newbie
Hola people,
I have a problem with CST, I guess because I´m a bit new with it:
I have a plane wave and just a metallic plane on the opposite. The metallic plane I move now by Parameter Sweep a millimeter closer to the plane wave.
-> Usually if I check now the phase I should be able to calculate the distance with R=phase_change(in rad) * lambda/(4*pi) * 1000
I get more or less a linear outcome in the phase, But I don´t get the 1 mm!! So what is wrong?
Thanks a lot!
Thanks a lot!
