Tan_Isn
Newbie level 3
I've encountered with such problem while designing in CST:
when I define two or more components that should intersect each other (for example, a silicon substrate with metal vias inside) the program doesn't automatically detect the intersection.
It is said in"Getting started" manual that there should be an automatical detection.
I wonder whether there is some built in tool where I should switch on automatical detection or I should reinstall CST?
One more, when I choose Boolean/perform Intersection Check, then "trim highlited shape", the result is following: the substrate is trimmed by the boundaries of vias.
But when I move the vias, consequently, at the previous place of the vias there are holes, left from the previous operation ('trim').
Can CST make automatical intersection of shapes without making holes, in case if the intersecting component changes its location?
I've already created the example of coaxial bend with a tuning stub (given in Getting started).
CST automatically detects the intersection of outer cylinder, whilst doesnt detect the intersection of the inner cylinders. It is strange.
I really hope that anyone can help me
Thanks
Thanks
