CST: Define a material with complex dielectric constant
charlyy
Newbie level 2
Hello,
I'm using CST Microwave and I would like to define a layer with a complex dielectric constant and I don't know how to proceed. Could you help me?
Thanks
complex dielectric constant for material
Hello Charlyy,
A complex permittivity means there is some losses in the dielectric. So you can put a losses by increasing the tan(delta) in the material properties.
Hope I help you
regards
piboo
cst+negative epsilon
hi
yes i agree with piboo . complex permitivity means you have loses in substrate.
inorder to model losses you can either mention loss tangent or conductivity
i hope it helps
regards
loss tangent cst
For your problem, you need to write epsilon and mu in terms of tangent delta electric and magnetic. (For dielectric and magnetic losses.) You need to also enter conductivity losses, if present. Just look at the freq dependent formulas for complex eps and mu, in an advanced EM book...
Off topic:
When I was working with metamaterials in the past, I tried to run a hypothetical problem in CST, which would include negative epsilon/mu. As it turned out, CST did not allow eps<1 and mu<1. Then I switched to HFSS.
This was in CST 5.0, i guess. Is it still the same for the newest CST version? Just wondered...
loss tangent and electrical conductivity cst
At the 2006 version of CST you can enter negatives number, but I don't know if the simulation works correctly with this.
cst dielctric material edaboard
Just a question about complex permittivy and tan(delta):
In some publications you can find:
EpsilonR=Epislon'+j*Epsilon"
which definition are you using to convert Epsilon" to tan(delta) ?
Thanks
dielectric - define
To piboo,
I think you can obtain Epsilon" by using Epsilon'*tan(delta).
complex epsilon in cst
if you are using e^jwt time dependence (most solvers use this), then:
EpsilonR=Epislon'-j*Epsilon"
where tan_delta_e (electric) = Epsilon"/Epislon'
complex dielectric constants of material
Thank you all,
I found it later but I forget to post it.
regards
piboo
