CST: choose smaller area in temporal monitor (.t3D) using VBA-code or MatLab
Hello!
I have rather big area of calculation and a I have temporal monitor. I need export many files (with monitor time step) that contains all coordinates and all field components.
Template Based Postprocessing doesn't help because it exports only 1 file, even if I set time sweep. But it can evaluate volume you need.
I have VBA-code, that exports many samples from temporal monitor. If the sample is big - it is impossible to work (beside I don't need hole volume of calculation). I want to extract smaller volume from temporal monitor and after that export it in a file. Is it possible?
Also I'd like to ask if it's possible to have an access to the field monitor in matlab, choose time position in .t3D (monitor file) and area that I want to export?
Heeeelp
Thanks in advance.
