cst farfield coordination
In fact, I have discussion with some guys here about the same matter two monthe ago. I don't know why I can't find it now. Anyway, you need to look for your far-field results in ludwig 3 coordination not the cartesian one. Of course, you have to have your radiation in z-direction, otherwise ludwig 3 will give no sence results.
Then, check the most potential field. If it is vertical, then it is vertical polarization, and vise versa. For circular polarization, I guess you will have the same radiation levels in both directions.
I have question for you: How I can check the Axial ratio in CST??
Let me know about your progress, it is important for me as well.
Regards
