CS5460A adc and LOAD CELL
nick703
Advanced Member level 1
surat
hello friend ,
i want to calculation weight of load cell using cs5460a to pic32 . if anyone has any reference to read adc value and how to transform weight (0 to 100kg) then please help me.
load cell capacity is o to 100kg.
i have read adc value and this is display in lcd between 0 to 65535 range . but when no load on load cell then reading is constant like 4566 so i want to say what is the exact calculation to display exact weight on my lcd using 24-bit Adc .
please help me !!
and also i want to know how to create exact calculation of weight with resolution up-to 1 gram. my load cell excited voltage is +5v .
The CS5460A seems a strange choice for an ADC - it is a "Single Phase, Bi-directional Power/Energy IC". I assume the load cell is a strain gauge bridge. As far as I can tell it is recommended to excite it with 9 to 12V although I cannot see why lower voltages wouldn't work. However, you only get 2mV/V out of it, full scale so will need a fair gain to get a decent signal. The PGA in the CS5460 is x50 maximum so you will not get high accuracy from only 10mV input.
Two resistors off the 5V supply don't make for a good reference. The CS5460 has one built in so why not use that?
Does your digital output value vary with load?
Keith
yes my digital output value vary with load cell . when no weight on load cell then give me result 4353 and when i put some load this value change to above the value of 4353 .
and also i don't about load cell scenario when i put some load on both side after one by one then result is opposed . like one side greater then 4353 digital value and other side less then 4353 digital value .
And here is the link to use cs5460a . so i use this adc.
https://sssysinfotech.blogspot.in/2010/09/weigh-scale-using-adc-cs5460-and.html
if any calculation or example must be help !!
yes u r right i measured this voltage is 2.5v. i got it but what is a factor to calculate on this basic referance volatage 2.5v.
The voltage difference between the two pins is approximately 2mV/V full scale. So, if you are applying 5V to the bridge you will get 10mV full scale. Measure the voltage with a multimeter between the two pins - it should be zero with no load. The CS5460 should therefore also give zero.
Keith
u means measure the voltage on IIN+ and IIN- pin of cs5460a which directly connected to the output of load cell?
that's give me a result of 0 volt without load and with load using of multimeter ? so what can i do ?
The voltage difference will be very small - 10mV at most when you place a load on the load cell - but you should be able to see that on a multimeter.
Keith
i didn't see the voltage difference but ADC reading is i getting when load put on load cell . so any coding problem if u help me then i post my little adc code.
hey kaith i getting value of ADC when of 1101 , 1201 ,(HEX) so on .. at that time original value is like that 1101 25 (HEX)something i neglecting lower value of ADC and i get only 1101 . so my question is if i have a count value every time 100 (HEX) value then how to calculate weight ?
I would suggest you test your ADC and software with known voltages (i.e. not the load cell) to make sure you are operating it correctly.
Keith
if no load cell is connected then how my result of ADC vary ?
Can u send me code of interfacing CS5460 i want it for my development.
Thanks in advance....
