CS5460 energy measurement
kirtan
Junior Member level 2
I working with CS5460 interfaced over SPI with Atmega32 (it has inbuilt SPI peripheral support)
part of the main code is given below. Problem is that after i start conversion DRDY bit is not set and the program waits in checking it forever..
I have gone through couple of thread and codes but can't figure out the problem
Kindly help me
int main()
delay_100ms(1);
init_uart();
init_spi();
CS5460_reset(); //this send 3 sync1 and 1 sync0 command and a command for soft reset
delay_100ms(1);
CS5460_init_configure(); //this load default values particularly clear status and mask register
delay_100ms(1);
CS5460_start_conversion();//do continuous conversion mode
delay_100ms(1);
send_string_uart("started convertion \r\n"); //just for knowing the status
while(!(CS5460_DRDY_ready())); //check if DRDY is set
CS5460_DRDY_reset(); //ignore the first computation cycle
while(1)
if(CS5460_DRDY_ready())
Vrms = CS5460_read_24bit(REG_VRMS);
Irms = CS5460_read_24bit(REG_IRMS);
Energy = CS5460_read_24bit(REG_ENERGY);
LaTeX Commands Quick-Menu:
