YES, but the PCB should have a transistorised buffer stage or a microcontroller where the crystal is supposed to connect to oscillate, and the same should be sufficiently powered...Cheers
The heart rate monitor isnt subject of these topic!
In all cases you can search for "hearth rate monitor"s at edaboard (see similar subjects) too_its a often handled question...
K.
just my opinion for control oscillator at 12Mhz...
operational amplifier do not work..or VERY expensive.
best solution is to use an MOS trans (2SK241) coupling by 5 pf at the OUT of oscillator (for best oscillation strap XTAL with 1Mohm or 820K résistor, it's fine.
Source of transistor is at the ground, and gate direct at Out Osc by 5 pf shunt by 470K (medium polarized at 1/2 VDD) Drain direct via + VDD by 3,3Kohms ... After one small cap 10000 pf on the drain and 2 Diodes GE 1n60 or SIL 1N4148 may be in doubler Vdd and one small led!
when XTAL oscillator work, Led Also!
12Mhz is high frequency OP Amp do not work at these frequency for detect. Sure!
Hope I help you sorry schematic is better but I do not make this in this forum sorry my bad english
