CrossWorks with Wiggler Debugger (ARM Philips) ?
SphinX
Advanced Member level 3
EGYPT
crossworks wiggler
Salam,
I have installed CrossWorks v1.4 as ARM C compiler.
My hardware consist of MCB2100 Evaluation board Connected to wiggler debugger interface.
I can compile my codes and program the ARM LPC2138 fine.
Running and stoping the code is working too.
But my problem is in the debugging.
Only the breakspoint work fine, The other debugging options such as Step into is not working, I don't why :-( ?
Do you have a solution ?
Thanks very much
skakz
Newbie level 6
arm crossworks 1.5
IF UR using the olimex cable
try crosswork 1.5 it works perfectly
