Hello everyone,
I want to generate a clock with about 4 MHz frequency (should be adjustable) which is very clean and sharp.
I can not access ready oscillators.
I have test a crystal collpits circuit but it is not sharp enough.
Any suggestions?
A quick slew rate requires that a device change immediately from high ohm to low ohm (or vice versa), so that current flow changes immediately.
It's the opposite of a low-pass filter. Which is like saying the highest frequency of a high-pass filter. Therefore a series capacitor is a handy way to create an abrupt spike, since it sharpens a spike into an even more abrupt spike.
A Colpitts oscillator generates sein wave, the opposite of sharp edges. You surely need to convert the waveform, e.g. by digital logic gates with schmitt trigger function.
Thanks, is there any specific known circuit for that.
What I want exactly is to have an oscillator with specific frequency, which an equivalent could be exist in form of oscillator pack.
What is "sharp"?
If it's a rise and fall time of a <20ns you could drive a 5V 74HC14 Schmitt trigger inverting gate with the colpitts signal (if it's 0-5v) to square up the signal.
Simulation showing how a series capacitor produces a spike-like waveform from a slightly rounded square wave. The series cap performs the differentiation function. (I called it a high-pass filter in post #5 because that is a more common name when used with sinewaves.)
Out2 amplitude is greater than Out1. By mixing or merging or adding the waveforms in some manner, it can sharpen the transistions.
Slew rate is altered further as the capacitor advances the phase (as is characteristic of capacitors). The behavior becomes obvious when Out1 versus Out2 are plotted X-Y fashion.
What is "sharp"?
However 74hc14 is too large for me.
I want to replace this circuit with a crystal oscillator so I do not have a large space.
Is there any small package one?
