karthi06
Junior Member level 2
- Joined
- Jan 16, 2014
- Messages
- 24
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 209
Hello,
Recently i have purchased crash sensors from following link:https://pacificgsm.com/miscellaneous?product_id=102
I have checked the crash sensor on the connectivity using multimeter.There is a beep sound when both red and black probe is connected to NO and NC pins of the sensor.But,when the orange coloured
rubber tap is pressed, the beep is disappeared.There are 2 pins for the sensor,:
1) NC pin
2)NO/C pin
The sensors act as a switch with no external power required.It is the external input for the pic to detect the collision and sends a sms. Is my connection of sensors to PIC in attached circuit is correct ?
Thank you.
1) NC pin
2)NO/C pin
Thank you.
