[SOLVED] countdown loop problem in c
adrian.eremencu
Newbie level 3
Newbie level 3
I have a problem with the following loop in C. It's a countdown for 4 digits(mm:ss).
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
void countdown(void)  // the countdown
  while ( min2 >= 0)
    while (min1 >= 0)
      while (sec2 >= 0)
    while ( sec1 >=0)
      sec1--;
      delay_1s();
    sec1 = 9;
    sec2--;
    sec2 = 5;
    sec2--;
  min1 = 9;
  min2--;
For example: if i have the values 15:30 (mm:ss) it decreases the sec2 val until is less than 0, then the value of sec2 is changed to 9 and sec1 is decreased by 1, and this process continues until all digits are = 0. The countdown works but when it reaches 00:00 it doesn't stop.
Depending on unsigned/signed variable type, countdown will either never stop (>=0 is always true for an unsigned number) or stop when reaching negative values. That's how you wrote the code.
Reactions: tpetar
    tpetar
I used signed var. But i think i know why it doesn't stop.
Let's say that i have 00:02. The procces will be the following:
00:02
00:01
00:00 and then when the sec1 is lower than 0 it exits the loop and automatically becomes 9, the sec2 becomes 5 and the min1 becomes 9 and in my main before i call this function i have while ( (min2 != 0) || (min1 != 0) || (sec2 != 0) || (sec1 != 0)), therefore the loop begins again. I will change the while loop in my main with an if statement and that should solve my problem.
It works now. Thank you for the support.
