Virtual clock is the clock which is logically not connected to any port of the design and physically doesn’t exist. A virtual clock is used when a block does not contain a port for the clock that an I/O signal is coming from or going to. Virtual clocks are used during optimization; they do not really exist in the circuit.
Virtual clocks are clocks that exist in memory but are not part of a design. Virtual clocks are used as a reference for specifying input and output delays relative to a clock. This means there is no actual clock source in the design. Assume the block to be synthesized is “Block_A”. The clock signal, “VCLK”, would be a virtual clock. The input delay and output delay would be specified relative to the virtual clock.
