bizoo
Member level 5
802.11b barker
hi
i am simulation 802.11 WLAN and in this study i am focussing right now only on header which is 128 bit and goes through DBPSK modulation and then i uses DSSS by using 11 bit barker code
now i am testing this small system by correlating the output i sent on the channel with 11 bit barker code, for time being i have no noise and i also assume perfect synchronization so i know when the packet start, as a result when i corerlate 11 bits of data on the channel with 11 bits of barker code, i get my original data back
but the probelm is that if i want to see a string of the retrieved bits e.g. 22 bits(chips) of data from the channel correlated with 2 barker codes (11+11=22) should give me back my two origianl bits and show it on the graph (matlab),
but problem is that i often get more than two peaks (3 in case of 22 chips, 5 peaks in 33 chips, 13 in 99 chips)and so on and so forth
can some one explain this phenomenon, 11 bits(chits) from channel vs 11 bits of barker is ok, this correlation shows one peak which accounts for one origianl bit,. but the problem arises if tend to see more than one bit on graph using correlation
waiting for prompt reply
br
hi
br
