copy palce16v8 to atfpal16v8
etgpsp
Newbie level 5
:?:hi everybody;last time i tried to copy content of place16v8 to atfpal16v8 with a programmr named tnm2000+;but it wasn't succesfull.anybody knows how is it possible to copy?and what is differences between them?
are you able to read data from old pal ?(place16v8)
thank you for reply ;yes i put the old palce16v8 on the tnm2000+ programmer and read it and save on pc with the both hex and binary format but when i wrote it to new atfpal16v8 the equipment that was working with old pal does not work with new pal.i want to know what is wrong?
one check can be , after programming the new pal(atfpal16v8)
verify and readback from new pal.
Hi; first time I did it all;I saw on internet that palce16v8 and atfpal16v8 have different way for programming and i have to convert binary or hex code (which has been read by programmer in the binary or hex format) to jed file ;i want to know is it true?
check your programmer supports atf16v8, atmel is using a different programming algorithm that is not having some low cost programmers.
hi;thank you for reply;it is universal programmer and have not atfpal16v8 but there is palce16v8 .do you think these pal are not compatible?
i thing the programming algorithm is different, palce16v8 uses gal16v8 algorithm for programming, if your programmer is not supporting atf16v8 you have to change the programmer or if you can make the programmer you can ask atmel for the programmer algorithm, they will send you a file you have to fill and return then they will send the programming algorithm for the atf16v8
if you are near my place i can help my universal programmer supports atf16v8
Reactions: etgpsp
    etgpsp
Thank you for replies.because i am not near you i will try to find another programmer.
