convolution of Gaussian pulses
purnapragna
Full Member level 1
gaussian convolution
What is the final result if i convolve two Gaussian pulses i.e.,
\[e^{-t^2}*e^{-t^2}=?\]
If i convolve for \[n\] times what is the result?
thnx
purna!
convolution gaussian
the result is
1/2*pi^(1/2)*2^(1/2)*exp(-1/2*t^2)
i used matlab for this by convert exp(-t^2) into freq domain the i multiplyed it by itself
then i reconvert it in time domain again
the code is
syms t
a=fourier(exp(-t^2));
a=a^2;
i=ifourier(a)
pretty(i)
for n time convolution you should do this n times
convolution of gaussian
Hey after i have done in Frequency domain i got the Gaussian pulse as the answer
But why like this can anybody explain?
thnx
purna!
convolution of two gaussians
Hi purna,
The result is a gaussian pulse sqrt(2) times wider.
You get this result by directly solving the convolution integral.
Another interesting way to consider this is as follows:
The Fourier transform (FT) of a gaussian pulse (in time) is a gaussian function (in frequency). This if found by solving the integral of the FT.
The product of the gaussian function by itself is a gaussian function, sqrt(2) times narrower. This is easy to show.
Going back to time domain, and using FT properties, you conclude that the convolution of a gaussian pulse by itself is a gaussian pulse sqrt(2) times wider.
Regards
Z
LaTeX Commands Quick-Menu:
