[SOLVED] Convert sine to square
E
elec_eng
how convert sine to square
Hi.
What type of circuit could i use to convert a sine wave to a square wave. The resulting square wave would need to have the same frequency and amplitude of the sine wave. The sine wave would be working in the range of 0-10kHz and 0-2 V p-p. Could this be done using a 741 op-amp?
Any advice would be helpful.
Thanks.
OPAMP in comparator mode can be used for this purpose
elec_eng,
A comparator will provide a square wave of the same frequency, but the output amplitude would be a function of the comparator supply voltage, and would be independent of the amlitude of the sine wave input.
To provide amplitude control, you would need some kind of regulator. An analog multiplier could be used as the gain controller.
Regards,
Kral
